Screenshot resolution
I have xibo working on a few 4k UHD displays 2160x3840 (portrait) and the screenshots I receive are only HD resolution which shows only a part of the screen.
Is there a way to chage the screenshot resolution to match the displays?
Display settings page -> edit display profile assigned to your device -> advanced tab -> Screen Shot Size
There is no such field. Only screenshot interval.
What CMS version are you using please?
Windows 10 with 1.7.9
Apologies for that, the setting I mentioned is available only for android profiles.
As for Windows, it will always use the configured dimensions (in display profile) or the primary monitor resolution.
So, you can try to enter your monitor resolution in the display profile.
Since you’re using Windows 10, could you please see if in display settings the ‘Change the size of text, apps and other items’ is set to 100%?
If not, please change it to 100%
I will check tomorrow as I do not have acces to the PC today.
Changing the resolution worked.
Thank you!
Great, I’m glad that did the trick.
