Schedule with broken schedules and screens not updating
Im currently testing an installation, 1.8.0 docker.
One day layouts were working correctly, yesterday the layouts stopped rotating the way they had been.
Restarted client, no joy.
Restarted server, no joy.
Deleted all layouts in the CMS, some deleted, but some remain after being deleted, subsequently clicking them results in the UI reporting “not found”.
To date I can still see them in the sheduler, but not delete them. with the same error as above.
log debug shows that appears to be the client having issues getting the schedule too:
logId runNo logDate channel page function message
1537 2529a0b 11/04/2017 16:08 XMDS Schedule POST Error getting the schedule. Not Found
1538 727ea6e 11/04/2017 16:09 XMDS Schedule POST Error getting the schedule. Not Found
1539 bc27f21 11/04/2017 16:10 XMDS Schedule POST Error getting the schedule. Not Found
1540 1feb683 11/04/2017 16:11 XMDS Schedule POST Error getting the schedule. Not Found
1541 6dffb94 11/04/2017 16:12 XMDS Schedule POST Error getting the schedule. Not Found
1542 6a3374d 11/04/2017 16:13 XMDS Schedule POST Error getting the schedule. Not Found
1563 05adab5 11/04/2017 16:07 PLAYER [RequiredFilesAgentThread] ScheduleAgent - Run POST Exception in Run: Unable to get the schedule
1564 05adab5 11/04/2017 16:09 PLAYER [RequiredFilesAgentThread] ScheduleAgent - Run POST Exception in Run: Unable to get the schedule
1565 05adab5 11/04/2017 16:10 PLAYER [RequiredFilesAgentThread] ScheduleAgent - Run POST Exception in Run: Unable to get the schedule
1566 05adab5 11/04/2017 16:11 PLAYER [RequiredFilesAgentThread] ScheduleAgent - Run POST Exception in Run: Unable to get the schedule
1567 05adab5 11/04/2017 16:12 PLAYER [RequiredFilesAgentThread] ScheduleAgent - Run POST Exception in Run: Unable to get the schedule
1568 05adab5 11/04/2017 16:13 PLAYER [RequiredFilesAgentThread] ScheduleAgent - Run POST Exception in Run: Unable to get the schedule
1569 7a595f9 11/04/2017 16:14 XMDS Schedule POST Error getting the schedule. Not Found
1570 5d3a70d 11/04/2017 16:15 XMDS Schedule POST Error getting the schedule. Not Found
is there a way of resetting the schedule?
What is the server running on? Windows or Linux?
If Windows, Docker for Windows or Docker Toolbox?
Sorry, i should have said! Its Linux.
First try deleting the CMS cache
sudo rm -r shared/cms/library/cache/*
Does that clear the records in the CMS?
Will try and report back! Thanks so much for your replys
