Schedule Problem
Hi I have created a layout, in the timeline have insert a region with about 40 images.
I create an event. ok
message from log
<?xml version="1.0"?>
schedule
layout file=“37” fromdt=“2016-02-19 08:30:00” todt=“2016-02-19 21:00:00” scheduleid=“109” priority=“0” dependents=“38.jpg,345.jpg,346.jpg,347.jpg,348.jpg,349.jpg,350.jpg,351.jpg,352.jpg,353.jpg,354.jpg,355.jpg,356.jpg,358.jpg,357.jpg,359.jpg,360.jpg,362.jpg,361.jpg,363.jpg,364.jpg,365.jpg,366.jpg,367.jpg,368.jpg,369.jpg,370.jpg,371.jpg,372.jpg,373.jpg,375.jpg,374.jpg,376.jpg,377.jpg,378.jpg,379.jpg,380.jpg,381.jpg,382.jpg,383.jpg,384.jpg,385.jpg”/>
if I insert other images in the timeline, the layout becomes invalid (397.jpg)
schedule
layout file=“37” fromdt=“2016-02-19 08:30:00” todt=“2016-02-19 21:00:00” scheduleid=“109” priority=“0” dependents=“38.jpg,345.jpg,346.jpg,347.jpg,348.jpg,349.jpg,350.jpg,351.jpg,352.jpg,353.jpg,354.jpg,355.jpg,356.jpg,358.jpg,357.jpg,359.jpg,360.jpg,362.jpg,361.jpg,363.jpg,364.jpg,365.jpg,366.jpg,367.jpg,368.jpg,369.jpg,370.jpg,371.jpg,372.jpg,373.jpg,375.jpg,374.jpg,376.jpg,377.jpg,378.jpg,379.jpg,380.jpg,381.jpg,382.jpg,383.jpg,384.jpg,385.jpg,397.jp”/>
truncate
can you help me
Could you please tell me what CMS / client versions do you use?
So if layout becomes invalid on the client, there should be some informations about it on your client’s status window.
Surely it’s not becoming invalid in CMS doesn’t it?
Is there anything different about your image with id 397? (Compared to your other images)
Hi Peter
Versione CMS 1.7.6
Client ANDROID 1.7.R59
397.jpg is identical to other images
the layout becomes valid.
Client : Invalid Dependent for layout-layout37falsefalseFri Feb 19 08:30:00 CET 2016Fri Feb 19 21:00:00 CET 20160. Dependent = 397.jp
CMS SCHEDULE : XMDSSoap4
schedule>
layout file=“37” fromdt=“2016-02-20 08:30:00” todt=“2016-02-20 21:00:00” scheduleid=“109” priority=“0” dependents=“38.jpg,345.jpg,346.jpg,347.jpg,348.jpg,349.jpg,350.jpg,351.jpg,352.jpg,353.jpg,354.jpg,355.jpg,356.jpg,358.jpg,357.jpg,359.jpg,360.jpg,362.jpg,361.jpg,363.jpg,364.jpg,365.jpg,366.jpg,367.jpg,368.jpg,369.jpg,370.jpg,371.jpg,372.jpg,373.jpg,375.jpg,374.jpg,376.jpg,377.jpg,378.jpg,379.jpg,380.jpg,381.jpg,382.jpg,383.jpg,384.jpg,385.jpg,397.jp”/>
layout file=“37” fromdt=“2016-02-21 08:30:00” todt=“2016-02-21 21:00:00” scheduleid=“109” priority=“0” dependents=“38.jpg,345.jpg,346.jpg,347.jpg,348.jpg,349.jpg,350.jpg,351.jpg,352.jpg,353.jpg,354.jpg,355.jpg,356.jpg,358.jpg,357.jpg,359.jpg,360.jpg,362.jpg,361.jpg,363.jpg,364.jpg,365.jpg,366.jpg,367.jpg,368.jpg,369.jpg,370.jpg,371.jpg,372.jpg,373.jpg,375.jpg,374.jpg,376.jpg,377.jpg,378.jpg,379.jpg,380.jpg,381.jpg,382.jpg,383.jpg,384.jpg,385.jpg,397.jp”/>
layout file=“35” fromdt=“2000-01-01 00:00:00” todt=“2030-01-19 00:00:00” scheduleid=“0” priority=“0”/>
default file=“35”/>
dependants>
file>jquery-1.11.1.min.js
file>xibo-layout-scaler.js
file>xibo-webpage-render.js
file>moment.js
file>jquery.marquee.min.js
file>jquery-cycle-2.1.6.min.js
file>xibo-text-render.js
file>xibo-dataset-render.js
file>flipclock.min.js
file>WeatherIcons-Regular.otf
file>weather-icons.min.css
file>weathericons-regular-webfont.eot
file>weathericons-regular-webfont.svg
file>weathericons-regular-webfont.ttf
file>weathericons-regular-webfont.woff
file>emoji.css
/dependants>
/schedule>
the string “layout file” is 460 characters and truncates 397.jpg in 397.jp
I can not add more images.
this only happens when starts the scheduling
Hi Michele,
My apologies I wasn’t aware of it, but there is indeed a bug regarding this character limit in 1.7 series.
Unfortunately it can’t be fixed in this series due to how this change would affect the players.
It is fixed in the 1.8 version (currently in alpha).
Again my apologies for all the confusion caused by it.
