Schedule every two weeks
Hi folks,
I have a layout that I need to display every fortnight. Currently the CMS does not have an option for scheduling a layout for every two weeks.
I dont want to use weekly as that then interferes with the default layout. (I dont want the scheduled layout showing every other week)
Is there any way to schedule a layout for every fortnight?
TIA,
Martyn
Hi Martyn
Weekly is the right option. You set weekly every 2 weeks (which means fortnightly). If you wanted it every 4 weeks you’d do weekly every 4 weeks etc
So for example, the following:
gives you this in the schedule:
Alex
Thank you that worked perfectly
