Hi guys,
when choosing the Event typ “command” there is no possibility to determine a time, only a date.
text under the date-field is “Start and end time will be defined by the daypart’s configuration …” that is the same when choosing “Campagne/Layout” or “Layout overlay” in Connection with a defined daypart.
Commands are executed once a schedule, therefore you should make a field to enter a time and a different text under
