Running Xibo for Android
#1
Xibo for Android is designed to run 24/7 without accepting any User Input. Therefore the application makes every effort to hide non-essential user navigational controls, such as the Action Bar and Navigation Bar. For most of the time we hope you do not have to interact with Xibo for Android.
Should a situation arise where you need to interact, perhaps to check on the status or make some configuration adjustments - the Action and Navigation bars will come back at a touch or cursor movement.
Menu
Xibo for Android uses a menu system that should be familiar to all Android users. The menu is accessible using the 3 stacked dots in the top right corner of the display. The most common menu items have been exposed by default.
Hide
Hide the Action Bar immediately (do not wait for the hide delay duration)
Status
Access the Status Dialogue.
Settings
Access the settings page.
Check Licence
Allows manual confirmation of the software licence.
About
Shows the about window.
Status Window
The status window is used to determine what the client is doing - in real time. The primary use case for this is troubleshooting when Xibo for Android is doing something you do not expect.
If you have asked for support it is quite likely that the support representative will ask you for a screen shot of this status window.
The information presented is split into 4 areas.
General Information
This section contains general configuration information and gives you the opportunity to see if the settings are correct. In particular the Licensed and Registered Status are important.
Licensed
This flag shows whether the software is currently licenced or not. Possible values are “true (trial), true (FULL) and false”. If the display is not licenced it will no longer download new content from the connected CMS.
Registered
This flag shows whether the display is registered with the CMS it is connected to. If not registered the display will not be able to download any new content or schedules.
CMS Status
The CMS status lists out the result of the last communication with the CMS. There are 3 messages transferred every collection interval (default 5 minutes) and all 3 should not have an error.
Schedule Status
The schedule status shows the current schedule on the device and the state of each layout.
All Layouts
Layouts that are downloaded but not necessarily currently in the schedule (for example a default layout will be downloaded, but may not be shown if there are other layouts scheduled).
Scheduled Layouts
Layouts currently in the schedule will be listed.
Valid Layouts
Layouts will be valid once all of their resources are downloaded.
Invalid Layouts
Layouts with missing resources or blacklisted content will be invalid and removed from the schedule.
Blacklist
If a media item is successfully downloaded and Xibo thinks it should play - but it doesn’t, under some circumstances it will be temporarily blacklisted. A good example is a video that has an unsupported codec.
Log Messages
Xibo for Android will list out the last 5 log messages recorded. This information might be requested by a support representative during Troubleshooting.
About Window
The About window shows the application version and EULA.
Closing Xibo
Please use the “Home” button on the navigation bar to close the Xibo for Android application.
Introduction / Table of Contents
