Rssfeed duration not working?
hello,
i have xibo version 1.8.1
at the timeline i have 2 rssfeed but when i set a duration at the feed he wont change or the time is incorrect.
i dont know how to fix it.
can somebody help me?
I would first recommend upgrading your CMS to the Latest version, which is currently 1.8.11. If you have any Xibo Players that are also not up to date I would recommend upgrading them too.
If the issue persists after the CMS and Players have been upgraded, please let me know.
i have tried to upgrade, but it had no effect on it
maybe there is a minum duration time to get it work?
this was the solution
I forgot to turn off the check for each feed
