RSS Ticker issue
I am having issues with the Ticker in version 1.7.4.
I have a RSS from google blogger that was fine in version 1.7.3 but after a complete reinstall (Whole PC OS and Xibo) the RSS comes out small. I am using [Title] and [Content] in custom
In the older version it would come out the same size as it was on Goole Blogger. But now is reduced in size.
Anyone know what is going wrong?
Thanks,
You can always tick the ‘override template’ checkbox and adjust the size, the same way you would do it with normal text.
I have used the override option (custom) the sizing makes no difference!
Any ideas?
