RSS issue - text is cutting off
Hi!
I have RSS feed on my monitors, the issue is at the end of the monitor the feed text is cutting off. So you can only see the half text . Thx for answer!
Could you export your layout and upload it to dropbox or similar and post it here?
If you don’t want to do that, please tell me what is your RSS feed URL, so I could check what could be wrong.
thanks,
Peter
Yes, here is the url´s
http://www.dn.se/nyheter/m/rss/
http://www.dn.se/sport/rss/senaste-nytt
I tried to reproduce your issue, but for me everything looks fine with your feeds.
I also tried different settings, effects (slide/scroll/marquee), more than 1 item from feed showed side by side and everything looks fine.
Maybe it’s something with region size and/or font size? (it’s hard to guess at the moment)
The best thing to do would be if you could export your layout (or reproduce only the rss feed issue in a new one and export it), if not that, could you take some screenshots showing the issue?
Potentially it could be few little things here and there, but since I can’t reproduce it, I would have to guess, in which case exported layout would be really helpful.
thanks,
Peter
Janne_Barckboat,
I had this same problem before. You don’t happen to be using an Android device? If so, the problem might be that some Android hardware is actually upscaling the displayed content and this somehow translates into RSS feeds not displaying correctly. I was able to download an updated firmware for our Android devices that corrected the problem. Not sure if that is what your problem is.
Hi!
Now this is on a Windows 7 computer with Xibo. Thx anyway.
