Version 2 includes the functionality to create and reuse Playlists!
Playlists are created in the CMS, under the Library section...
This is a companion discussion topic for the original entry at https://blog.xibo.org.uk/reusable-playlists-in-2-0-0/
When playlist (only pictures) widget is used there is no option for Scale type (Stretch or Centre). So the region will not be fullfiled with content from playlist widget. Is there any solution for that?
