Restrict Docker to listen on single IP
I have installed Xibo following the Docker on Linux guide here: Xibo for Docker | Xibo Digital Signage
All seems to be running fine post install and I am working through the CMS Post Install docs now.
We have the CMS running behind an Apache reverse proxy on a separate server which is handling all of the SSL for us. This part is working fine…
With our reverse proxies web servers we have a secondary NIC which is on a different network to the main server NIC. All reverse proxy traffic is directed through this network.
I would like to configure Xibo so that the web interface for the CMS only responds on the secondary NIC and not the main NIC.
Can this be done?
Thanks,
Jon
