For the original poster (OP) to fill in:
Completed on user behalf.
Introduction
As thumbnails are relatively small – should there be an option for a display to upload a thumbnail when it contacts the CMS to check for new content?
User Story
Our displays are behind a firewall, direct commands do not work
For the dev team to fill in:
Status
The current status and the username of the:
- Reporter
- Drafter
- Implementer
Implementation
A broad description of the changes required.
Effected Software
Which parts of Xibo are effected
DB Schema Changes
Any necessary DB Schema Changes
