HI I would suggest, if it were not already provided, this feature: replace multiple files in the image library at the same time when the file is already present. This feature would facilitate layout updating, at this time the replace media function only works with one image at a time.
thank you
Thank you for your post.
When you say replace multiple files in the image library at the same time when the file is already present
could you further explain what you mean by this or provide an example to demonstrate how you see this feature in practice?
Hi Natasha in this image yuo can see on the left the library of my xibo cms and on the right the list of images thah I need to replace. To do that now I have to do: select first image, then modify, choose replace , select the new image and start upload for all images one by one. The new function should allow to select all imges to replace from xibo and after select the new images from drive that match the names.
