Remove schedules
Hello, how are you, I have a question, I registered a schedule on a screen, then I added another and now the 2 schedules are being played, if you want to put new schedules, how can you delete the ones that are already registered so that only the new one passes
Reschedule the layout you don’t want to show. Tell it to end now, and only your second layout will show.
You could also use priorities. Set the layout you want to display to a higher priority than the one you don’t want to display.
