My remote datasets does not updating automatically with the task Fetch Remote DataSets, it’s only changed when I edit a layout.
This is my log:
Running Task 6
Running Task Fetch Remote DataSets [6]
Checking permissions against the logged in user: ID: 0, Name: system, UserType: 1
Order of processing: ["1 - "]
Processing Dataset. ID:1
Skipping dataSet 1 due to it not being accessed recently
Finished Task Fetch Remote DataSets [6] Run Dt:
Why there is Skipping dataSet 1 due to it not being accessed recently if the remote json is changed?
And why when I change any layout the dataset is updated?
Thanks.
That doesn’t impact whether the dataset is synced or not. The dataset must be in use on a Player, via a layout. ie one of those 5 layouts would need to be scheduled and actively being shown by a Player device before the dataset will start syncing.
