Remote dataset processed data, but emtpy list
I’m having trouble with a remote dataset in Json format.
The ‘test data url’ gives a list and processed data, but the table is empty.
Did a ‘Fetch Remote DataSets’ task and waited for several hours. But the table shows nothing. I use version 1.8.11.
I would expect that the ‘test data url’ values in processed would be the list values in the table.
What could be wrong?
The output of the 'test data url" is:
“entries”: [
“condor”: [
“location”: “warehouse 1”,
“units_power”: “kWh”,
“Recent_energy”: “151800.36”,
“Dag_energy”: “151676.74”,
“Jaar_energy”: “139652.83”,
“units_volume”: “liters”,
“Recent_volume”: “2473.00”,
“Dag_volume”: “2473.00”,
“Jaar_volume”: “2188.69”
“location”: “warehouse 2”,
“Recent_energy”: “103580.04”,
“Dag_energy”: “103309.26”,
“Jaar_energy”: “94388.97”,
“Recent_volume”: “1629.00”,
“Dag_volume”: “1608.62”,
“Jaar_volume”: “1464.38”
“number”: 1,
“processed”: [
“Recent”: “151800.36”,
“Dag”: “151676.74”,
“Jaar”: “139652.83”
“Recent”: “103580.04”,
“Dag”: “103309.26”,
“Jaar”: “94388.97”
“messages”: [
“Processing 1 results into 3 potential columns”,
“Processing Result with Data Root condor”,
“DataRoot is an array”,
“Processing 0”,
“Processing 1”,
“Consolidating entries”,
“There are 2 entries in total”
Do you see current date in the Last Sync column on DataSet page in the row with your remote dataSet?
If yes, and you still don’t see any actual data in the dataSet, please enable CMS debugging, let the task run again (you can force it to run on Tasks page) and collect the logs, you can then send the logs to me via private message.
Hello Peter,
Last Sync is empty; manually started ‘Fetch Remote DataSets’ and waited some hours. Als used the dataset in a layout and scheduled it.
The Last Sync stays empty.
BR, Bert
