Reminder using xibo
hello… i would like to make task reminder using xibo by date. i want to set the item in data set and it will only display only he current date.
please anybody give me the idea.
thank you
You can have a ‘Date’ column and ‘reminder’ text column in your dataset, then in ticker/dataset view a filter like:
DAY(Date) = DAY(CURDATE()) AND MONTH(Date) = MONTH(CURDATE())
Where ‘Date’ is a column name with dates in your data set
Or have Start / end columns with dates in your data set and then filter like:
NOW() > Start AND NOW() < End
You can also set a message to display when no data is returned from the source - ie what it should display everyday apart from the dates you set in your dataset.
In both cases you’d have the ‘Reminder’ column on a Appearance tab to display the text of the reminder from your dataset.
