Reinstalling Module
3.3.4 docker
How do I go about reinstalling Webpage Module?
Thank you
I am unsure as to how you have uninstalled a module, so first check from the Modules page and if it is showing as disabled, re-enable it.
If you have manually deleted it from the database you would need to restore a backup from before it was deleted.
When you disable the module, you then have an option to uninstall it. I uninstalled it and thought I could reinstall it hoping that would fix my issue.
Thank you,
John
Ah OK, you would still need to restore from a backup or a direct database edit to get that back.
So there is no way to actually reinstall the module without doing a complete restore?
Thank you
