Hi all , im having a bit of an issue here, i have been testing layouts and that on a new test setup and all has been going fairly well with only a few minor issues but now im having a issue where sometimes on the client all of the regions except from a powerpoint and a picture just show up as a white area .
What CMS/player version are you using please?
Do you use background image? If so in which format is it? (should be .jpg for windows clients)
cms version 1.78
client veriosn 1.78
i am using a background image in jpg format
here is the log from that screen if it is at all useful to resolve the problem
``22975 2016-07-19 00:37:26 Client [ScheduleManagerThread] ScheduleManager - Run Exception in Run: The process cannot access the file ‘C:\Users\Herath\Documents\Xibo Library\status.json’ because it is being used by another process.
22974 2016-07-18 16:46:13 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22973 2016-07-18 16:46:13 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22972 2016-07-18 16:29:34 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22971 2016-07-18 16:29:33 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22970 2016-07-18 16:29:33 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22969 2016-07-18 16:29:33 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22968 2016-07-18 16:25:18 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22967 2016-07-18 16:25:18 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22966 2016-07-18 16:23:17 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22965 2016-07-18 16:23:17 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22964 2016-07-18 16:11:36 Client [LogAgent] LogAgent - Run Exception in Run: Could not find file ‘C:\Users\Herath\Documents\Xibo Library\stats.xml_131133282945824532’.
22963 2016-07-18 16:06:32 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22962 2016-07-18 16:06:32 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22961 2016-07-18 16:03:30 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22960 2016-07-18 16:03:30 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22959 2016-07-18 16:03:30 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22958 2016-07-18 16:06:32 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22957 2016-07-18 16:06:32 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22956 2016-07-18 16:03:30 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22955 2016-07-18 16:03:30 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22954 2016-07-18 16:03:30 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22953 2016-07-18 15:52:45 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22952 2016-07-18 15:52:45 Client [UI Thread] WebMedia Unknown exception Object reference not set to an instance of an object.
22951 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22950 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22949 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22948 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22947 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22946 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22945 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22944 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22943 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22942 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22941 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22940 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22939 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22938 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22937 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22936 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22935 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22934 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22933 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22932 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22931 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22930 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22929 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22928 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22927 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22926 2016-07-18 15:47:07 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22925 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22924 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22923 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22922 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22921 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22920 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22919 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22918 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22917 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22916 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22915 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22914 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22913 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22912 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22911 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22910 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22909 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22908 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22907 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22906 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22905 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22904 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22903 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22902 2016-07-18 15:46:57 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22901 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22900 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22899 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22898 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22897 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22896 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22895 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22894 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22893 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22892 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22891 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22890 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22889 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22888 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22887 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22886 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22885 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22884 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22883 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22882 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22881 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22880 2016-07-18 15:46:47 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22879 2016-07-18 15:46:37 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22878 2016-07-18 15:46:37 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
22877 2016-07-18 15:46:37 Client [UI Thread] MainForm - ChangeToNextLayout Layout Change to failed. Exception raised was: Default layout
22876 2016-07-18 15:46:37 Client [UI Thread] MainForm - ChangeToNextLayout Prepare Layout Failed. Exception raised was: Default layout
Do you have fully qualified path to your CMS library in CMS settings?
‘Library location’ section of this post Xibo CMS Post-Installation Setup Guide
If that does not help, you might need to export your layout for us to try.
under library location in the cms i have C:\xibofiles\ which from what i can see seems right .how can I get the layout to you, tried attaching it to this but zip files are not allowed.
@Peter Did you guys ever resolve this? We designed a layout for a fundraiser this weekend that has a countdown, and this error has suddenly appeared hundreds of times since that layout was deployed. I’m assuming that this relates to the fact that every few times the layout loads, it does not display the region containing the countdown. My guess would be a race condition between the loading of the script and the DOM.
Could you send me your layout please?
Upload it to dropbox (or similar) and share the download link with me via private message.
