I’m testing the APIs for integration with our custom application. One of the simple tests was to be able to access the details on widgets (and playlist) assigned to different regions in a specific layout. I’m using the following request in our trial environment:
GET /api/layout/status/{layoutId}
However the return response does not contain the region details
“layoutId”: 46,
“ownerId”: 4,
“campaignId”: 16,
“parentId”: null,
“publishedStatusId”: 1,
“publishedStatus”: “Published”,
“publishedDate”: null,
“backgroundImageId”: null,
“schemaVersion”: 3,
“layout”: “FMTV Test 2”,
“description”: “”,
“backgroundColor”: “#000”,
“createdDt”: “2022-04-01T20:40:42.000000Z”,
“modifiedDt”: “2022-04-01T20:45:22.000000Z”,
“status”: 1,
“retired”: 0,
“backgroundzIndex”: 0,
“width”: 1920,
“height”: 1080,
“orientation”: “landscape”,
“displayOrder”: null,
“duration”: 119,
“statusMessage”: null,
“enableStat”: 0,
“autoApplyTransitions”: 0,
“code”: null,
"regions": [],
“tags”: null,
“drawers”: [],
“actions”: [],
“permissions”: [],
“campaigns”: [],
“owner”: “fuelmediatv”,
“groupsWithPermissions”: null,
“folderId”: 1,
“permissionsFolderId”: 1,
“isLocked”: {
“layoutId”: 46,
“userId”: 4,
“entryPoint”: “web”,
“expires”: “2022-04-01 16:50:20”,
“lockedUser”: false
