Reduces content at client embedded on region
HI ,
For several years , I use Xibo . And with very good results, thanks to their work. .in this week I started to have a problem which I commented :
I use windows 7 x86 , client 1.7.6 , 1.7.4 cms .
I have embedded a web page html ( comes from loclahost ) in the previous CMS is correctly ( pic1 ), the embedded option in " best fit" .
but then the player the embedded content ( pic2 ) is reduced to show only a tiny portion .
I’ve tried multiple things and various different pc and nothing yet. In fact for months that used it so smoothly.
I appreciate your help.
Hi!
I suggest you to try
1- Options other than "best fits"
2- Try to fit your region to your background. Sometimes the software struggles like that.
3- Try another web page. Does it fit? Or not? If another web page does fit as you like maybe you have to change your html code a little bit.
Hope it helps!
HI ,
Thank you for your advices. I have done so far, a change in the sizes of html code , as you also said .
But as so far “best fit” mode worked perfectly , to come to understand what was the reason.
Thanks again , we are in contact.
hi ,
Please , I need to see this matter , now I have the same problem of reduction in the player client in all options : Manual position / open natively / best fit . Only in the client .
Thank you, I wait for your quick comments.
