Quick Question about Xibo Player
Hi There,
I’ve been noticing that the xibo player splash screen shows up after layouts are being played. And it seems to be repeating every 10 sec 3 times.
Is that something new in the latest version of the player? I didn’t notice this in the previous one before I upgraded. I remember the splash screen will only show up when the player is loading but will no longer show up right after unless there’s no layout scheduled.
Thanks!
You may have something scheduled that the player is not able to play - so it falls back to the splash screen. Something like an empty Layout would cause this - or a layout that only contains a media item not supported by the player - that sort of thing.
