Question regarding 1.8.1
Hello!
I’ll try to explain my question using this example.
I have 5 screens with one layout for each screen, is it now possible to some how add media to one region in all those layouts at the same time?
Not at this time, you will need to edit each layout individually and add your media to a specific region on them - or do this via API, but you will need specific playlistId on each layout to do so ie also can’t be done in one call.
If you’d want to change media that is assigned to all those layouts, then that can be done in all of them with one action - replace media in library (either by web ui or API).
Alright, I see…
Thanks for fast answer Peter
