Hello, i need someone how can ceck the proxy implementation in Xibo CMS 2.2.2.
i installed it on XAMPP with a windows client on a seperate machine.
now i tested the Darksky weather module together with an api key.
since i am behind a proxy i need to get the proxy information filled in under
Settings → Network
but this wont work as the log states: unsupported syntax:
good morning masterbug !!
where says Proxy URL (http://my.proxy.com), there you put the proxy address.
where Proxy Port says (8080), there you put the port
where Proxy Credentials says (user:password), there you put your proxy credentials
then you save the changes It would have to work for you.
Hope this can help you.
