Problems with the embedded HTML module on Android Player
I’m have a heck of a time getting the embedded HTML module working on the Android Player. I’m using a miniand device for the player. One of the things that is causing a problem is that the black android nav bar on the bottom of the screen doesn’t get dismissed like it does for video playback. Has anyone had any experience with this?
Unfortunately we’ve not tried the miniand device.
The black bar at the bottom and the top bar should be hidden regardless of the content you are showing and if they are being hidden for one then I am surprised they are not being hidden by the other (the hiding is a function of the player, not of the content being shown).
It usually hides on a timer - unless you’ve overridden the default settings in your android display profile.
Some devices ship with their own non-standard navigation bar (the black bar) and these can cause problems. You could check on your device whether you can switch to the default android launcher, which might help.
