Hello everybody,
me again. I wanted to insert a text in the text widget now … if I insert the as seen on the images and then on o.k. do not click then the whole text is not synonymous if I insert a picture yet this is not displayed. in the xibo version 1.7.5 it all worked.
Can you help me please.
Ok the Proplem is solved.
I support Kusselin via telephone.
We insert some kind of text from Facebook and in the background (in the sourcecode)there a many faulty tags.
So in the represantion there are a lot of faults. We clean the text from the sourcecode, an everythink
works fine.
Greetings Torsten
Hallo torsten,
Habe gerade im xibo forum was über rss ticker gepostet…weisst du wo ich oder xibo den fehler mache??
Vielen Dank
Gruss
Markus
