Problems with playback of two layouts
Dear developers, we are faced with such a problem during testing your Xibo. There are two layout. In one of these 5 videos in the other two movies. Exhibiting broadcast so that the first model is broadcast for example 1 hour, and the second is repeated every 10 minutes. But after the second layout played - first video starts not from the break and the first video in first layout.
If I understand the issue correctly, then I think it’s working as intended.
Basically when layouts change from your second layout to the first, it’s fully loaded again so it will start from the beginning not from the point in which it was ‘interrupted’ by the second layout.
Is it possible to reproduce the layout not from the beginning of layout and on the break or at least the next video in the layout ?
I am afraid it’s not possible at the moment
