Problems with pdf documents in layouts
Specify the full CMS version you are using, including the revision number.
3.1.2, Self Hosted
Include the Player type you are using.
Android, Windows
Include the full version, including the revision number.
Newest DL from xibo.org
Please provide full details as to the issue you are experiencing, include screenshots where possible.
We are currently in the process of changing our old, selfmade signage system over to xibo. I installed the newest CMS docker image and prepared a test device (windows player) for our marketing department so they can start building some layouts and get familiar with the CMS.
Now they contacted me with the following problem:
They built a layout using a pdf document (60 pages, 260mb) that should change page every 11 seconds
xibo
This works fine in the preview, but the windows player seems to skip some pages!
We also ordered a DSCS9 device, so i tried the layout with it and it works even less. The device flicks through all pages in seconds and then just displays black.
Any Ideas why this happens?
Thanks!
