Problems upgrade 1.7.9 to 1.8.2 "Not Found"
Good afternoon!
I am trying to upgrade from version 1.7.9 or perform a new installation, but even changing the Document Root continues receiving “Not Found” when trying to access the link.
Here’s part of the Document Root configuration in /etc/apache2/sites-enabled/000-default.conf:
DocumentRoot / var / www /
Options FollowSymLinks
AllowOverride None
</ Directory>
<Directory / var / www / web>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow, deny
Allow from all
</ Directory>
I can access through http: // my-address / xibo. After clicking on “web”, then I get to the part of the pre requirements and clicking “next”, "Not Found The requested URL / xibo182 / web / install / 2 was not found on this server."
Would I have to change something else in Apache?
Thank you.
DocumentRoot should be /var/www/web that’s assuming that you’ve already put 1.8.2 files in place of course.
Please do look into URL rewriting as well - http://xibo.org.uk/manual/en/install_environment.html
