Hi, i’m trying to restore a docker mysql backup to a new machine, but i see the migrating process, but without any changes at the end, i’m doing something wrong? (I put the files from “/opt/xibo/shared/backup/db” on the same place and the same for the files from “/opt/xibo/shared/backup/”)
i here is the log that generates when i run the “docker-compose up” command
If you already have a docker installation on one machine, its not really necessary to run a SQL backup, etc… just down the containers, copy the whole /opt/xibo folder between machines and then up the containers
