Problems installing Xibo 1.8 Alpha on Ubuntu 14.10
I am trying to setup a preview version of 1.8 Alpha on a Ubuntu 14.10 platform. When I go to URL http://127.0.0.1/xibo on the server, I proceed successfully through all the prerequisite checking, but when I then click “next”, I receive the error:
“xibo/web/install/2 was not found on server”
Any suggestions or guidance on how to correct this? Thanks in advance for any suggestions
You may be running under an alias? (/xibo) - in which case you may need to adjust your rewrite rules: http://xibo.org.uk/manual-tempel/en/install_environment.html
