Problems adding or removing layouts to groups of players.
Vest 1.8
I’m having trouble adding and removing layouts in groups of players.
In my test I did the following:
I’ve created 2 groups of players and I’ve scheduled different videos for each of them.
When I change the player from one group to another. The videos are not changed even though I shut down the player, and then run again. It does not get the updates.
To be able to update I have to schedule some video directly to the player, only then it picks up the updates made previously.
Go to the Displays page, and for each display, edit it and save making no changes. That will clear the CMS side Player cache.
Alternatively, you can do the same by editing the display settings profile you have assigned to your displays, and saving that, again making no changes. That will then clear the cache for all displays that use that profile.
