I’m facing issues with sub playlist. I have created the playlist and I have assigned this to the layout using Sub playlist. I’m not finding any error while putting all the sub playlist inside layout. After publishing the layout the status of the layout showing “This layout has not been built yet”
If we assign this layout to display every collect interval time, it will download that particular layout again again
Ex: If the Collect interval is 10 min, then every 10 min the layout will download again and again
Sounds like you don’t have XTR setup and running. It’s a requirement for subplaylists to work properly.
If you’re using a Docker-based install, it has been done for you already, and so you need to troubleshoot why your tasks aren’t running.
If you’re doing a custom installation, then you need to go back to the install guide and check you setup XTR correctly and that it is being run by the same user as your webserver.
Thank you so much for the response.
I have one more question on the playlist, when we create the layout and if we put sub playlist inside layout and publish the status of the layout will be “This Layout has not been built yet”
Because of this the display always shows downloading status ??
