Problem with access to template
Hi
I’ve made a template and given the rights to “user”, but when they open the template trough the layout view, they can’t change the image widghet. Why? Going crazy?
Hello and welcome to the Community!
Have you also given access rights for the Image as well as the Template itself?
You can create Folders and set access levels on the Folder, anything contained within that folder will inherit those settings.
Seems like you want to change the template but you only open it in the view mode?
You should create a New layout and choose the template you created :slight_smile:
