Is there a way to order data in a dataset first on the first column and also on the second column?
now i sort on one column, but the data in the second column is a kind of messy.
dataset view / ticker can use SQL clause for ordering data.
so in order field you could put column1 DESC,column2
This sorts everything by column1 (descending) first, and then by column2 (ascending, which is the default) whenever the column1 fields for two rows are equal.
