Problem executing my MSI file
Hi All,
I’m trying to replace splash screen on XiboClient (written in #C) and make MSI file of my project using Advance Installer 12.8.
The problem I have is this error message appears when Save button is pressed
’Client found response content type of ‘text/plain; charset=UTF-8’, but expected ‘text/xml’.
The request failed with the error message:
Your client is not the correct version to communicate with this CMS.’
I’m slightly confused, my MSI file is exactly as same as ‘xibo-client-1.7.6-win32-x86.msi’ all files and folders are in same order.
Anyone with bright idea ?
You are trying to connect to a CMS that doesn’t support that version of player. Your player should be sending the v parameter along with the URL to XMDS - it is sending a v parameter that the CMS doesn’t support.
Thank you dan that has done the magic my new MSI file is working without any errors. I had to download XiboClient version 1.7.7 and exchange some file into my MSI and that has worked.
Zed
