Powerpoint issues
Hi
I’m tato, i have problem sending powerpoint into player “Powerpoint is not enabled on this
display”. i alo have following the instruction on the other discussion, but didnt fix the problem.
Please, help me to resolve the issue.
Regards
So did you enable it?
Display settings → edit display profile assigned to your device and:
Here you can find more information about power point - PowerPoint | Xibo Digital Signage
great help peter…
thanks
sorry…come again,
the player keep asking whether we want to open the file, due to security issue. (pop up windows), so i have to click manually the option.
how do we solve this?
regards
It is described here: http://xibo.org.uk/manual/en/media_module_powerpoint.html
Under “Prepare your Windows Players”
