Powerpoint display does not appear in region
Continuing the discussion from Powerpoint display does not appear full in region:
2 things.
1 - Perhaps set the display resolution in display profile in CMS (Display settings -> edit display profile > assigned to your device -> location tab)
2 - Make sure display scaling is set to 100% (in Windows display settings) - especially if you’re using W10
In reference to the first point how can I do, I have enabled the power points in the layout but I still don’t see the PowerPoint
What should I do?
About XIBO
Version 1.8.11
Player 1.8.12
Ensure that you have first enabled Powerpoint in your Display Settings, as explained here: PowerPoint Module
Please refer to the Enable PowerPoint section.
Thank you
