Possible to hide 'Private Folder'?
CMS 3.3.0
When setting for a user Home folder (not under the root), it will see all folders as “Private Folder”
Is there a way to hide it?, so Home folder becomes “Root” folder for that user? as the Private folders are not really relevant to that specific user, hence should not be presented for him…
Hi, so the user has been given access to sub-folders within a “main” folder which they have not got access to. How this is presented to the user (with the Root Folder set as the home directory) cannot be changed. The reason for this is you may in the future, need to share a folder above and we need a way to represent that.
