Possible bug with date format in collumn setting of dataset
CMS: 3.3.3
Heho
My json returns the format “2023-02-16” (yyyy-mm-dd) and I want to change it to “16.02.23” (dd.mm.yy).
I set the date format in the collumn settings to “d.m.y”, but the date is shown as “16.02.2023 00:00”
Maybe my settings are wrong, but in PHP that should be correct.
EDIT: In the dataset view it’s shown as 2023-02-16 00:00:00
I think I need to switch to formula
Hi and welcome to the Xibo Community.
The result is always a MYSQL date/time object. If you have JSON as 2023-02-16 then you would want that set to Y-m-d. If you wanted that formatted differently to display then use a String type column and populate that with a formuat to format the date how you want.
somehow it worked after a day now xD I set the value again to d.m.y
Thank you
