Positison of Xibo 1.6 Ubuntu Player
Hello!!
I was wondering if I can start the Ubuntu player window (ver. 1.6.4) on the upper left corner of the screen.
Now the payer is starting at the middle of the screen.
Thank you!
All the configuration options for the Player are defined in defaults.cfg - you simply copy the ones you want to override in to site.cfg
There is no option to configure the position though - only the size I’m afraid.
That Player is unsupported now so there won’t be any further official updates to it.
This info must be somewhere inside the XiboClientpy.
It may be possible to move it with a code change, but there is no configuration option for it.
