Playtime in minutes possible?
Hi Xibo-Team,
just a simple question, is it possible to set the play-time in minutes?
I can set only steps of 5 minutes:
Zwischenablage01
Lets say a Layout should play ftom 00:00 to 24:00, I have to set 00:00 to 23:55.
But till 23:59 would be more preferred. So between 23:55 and 24:00 (or 23:59:59) the default layout shows up.
Hi, if you click on hours/minutes/seconds you can then free type it in:
Hi, I tried this, but the fields are not clickable in Firefox (90.0.2).
I can only change the time with the arrows up/down in 5 minutes intervalls.
Tried in Edge, here I can change the values. But I dont have the seconds field too (neither Firefox nor Edge)…
You could set seconds by changing the Date Format in Regional Settings to allow for this when displaying dates, however it should be noted that the Players wont be accurate to the second.
Could I ask if you could confirm the version you are using?
We are currently looking into the issue with FireFox and will update here!
Thank you
Hi, thank you, I was able to get the Seconds!
CMS: 3.0.1 (Linux/Docker)
Browser: Firefox 90.0.2 on a Win10 21H1 (up to the most recent updates)
Thank you for confirming.
The dev team have opened the following issue:
