Player USB Storage
I did see the Log of the newest player version. On the list, have the “Added Support for USB Storage”.
This could be the solution for one of my Android Displays. I installed the new version, but the my USB storage is not shown.
What could be wrong?
This feature is indeed to use pen drives as media storage?
Yes exactly that. It will allow you to use a USB storage device for the Player library.
The device must be formatted with a file system your Android device can read/write. If that isn’t the case you’ll see a log message on the status screen to that effect (assuming the Android device can mount the storage at all).
