Player not listed problem
Installed the player on same pc as cms. When I hit save it says awaiting approval by admin. Display is not listed in display list on cms. I can see the display name in the schedule window. Using 1.8
In this case it might just be browser cache, if it is detected there then it should be on the Displays page as well.
Alternatively you have some filter applied on Displays page perhaps?
I was using edge so I tried Chrome and it is visible in chrome
