I went to restore from crash my XIBO CMS V1.7.8 and my player can not be connected on it.
I’have this error :
Status
The request failed with the error message:
Can you access the CMS itself with the same URL as the on you provide in the player’s options?
1.8 series will require more modifications(DocumentRoot and URL rewriting), but 1.7 series should be ok, especially if it was working before, unless of course something has changed without your knowledge.
Thanks for your prompt answer. So I’m going to stay with the Version 1.7.8
Yes I can access to the URL from the virtual host with Win7 where I installed the player.
The URL https://www.acme.org/xibo/ is giving the login page of the XIBO CMS
The strange thing I went to change of network as I’m at ho. The player is connected and working
Is it the root cause? What are the TCP Port I have to check ?
in 1.7 series, at least by default that’s only 80 (http) and 443 (https) with 1.8 there is also port on which XMR runs, but in 1.7 it’s only those two that playwe may use.
Hi Peter,
Sorry for the delay, I fixed some part but I’m stilling blocked.
The fact is I’m connecting 2 players through a university wifi hotspot network.
The network service doesn’t want to a give an login on the hospsot for any host without owner of this login. That’s raising up the difficulty. When I entered my own login everything is working well.
As the hotspot is blocking the DNS, I would like to know if it’s possible to bypass with a specific TCP/UDP way.
Could explain what’s the XMR ?
Do you think the XMR using could ginve an issue?
