I’m new Xibo user, I just successfully setup Xibo with Docker on WIndows10, I changed the CMS to port 8888 and I can access the dashboard via browser successfully, but I haven’t setup SSL yet (that will be my next task), it is fresh Xibo install, when I connect first player(android) to CMS, to address http://192.168.1.100:8888 it was failed “Unable to connect to CMS Address”.
Does player need https/SSL connection to connect to CMS?
What could be the issue?
