Is that on windows or android or what is the command? just reboot?
Apart from that being rather unusual for reboot command to run that often, I’d still expect that to be executed for better or worse.
Is that scheduled event command type or layout with shell command on it?
Thank you for confirming that ie the issue seems to only occur with Scheduled event type command with repeats set - I will try to recreate this tomorrow and see if it is indeed a bug.
