Plan playlist items on certain days
Introduction
Currently you can set the expiry date of items inside a playlist.
However, I would also like to be able to select the days on which an item is displayed.
User Story
I don’t want to use the calendar to plan my items as it’s not very user-friendly. Therefore, I use playlists that are inside planned layouts. Inside the playlists, I can easily plan the items, but unfortunately, there is no option to select certain days when an item should be displayed.
