PHP CVE-2026-109618 CVE-2026-109619 patch possibly?
Hi everyone,
Could you please check the package names for version 3.3.13 in your download section? The CMS package contains the Docker files, while the Docker package appears to contain the CMS files—at least judging by their contents after extraction.
It would also be helpful if version 3.3.13 identified itself as such on the login page and/or in the “About” section. Both still show 3.3.12. So far, only the Docker container’s image tag suggests that I’m running a newer version. I’ll investigate this further.
Thanks in advance!
Thank you for flagging this – it has been resolved.
See:
Here’s a silly question, on the xibosignage.com release notes page, I followed the following instruction: Self-hosted customers: Update your docker-compose file to the release-4.5.0 tag, then pull and redeploy.
I’m back up and running, but did I downgrade myself back to 4.5.0, or is 4.5.5 somehow automatically applied?
Hi, thank you for posting.
You need to be updating to the 4.5.5 tag. I have corrected the changelog to rectify this.
Thank you for bringing it to our attention.
Ah, that’s what I figured. Thanks for all you do.
Just wanted to say nice work by the dev team to get a fix pumped out quick. Much appreciated gents and ladies.
Thanks Jon, I will pass your kind comments onto the team :slight_smile:
Hi, I just updated to 4.5.6, Docker installation on Ubuntu 22.x LTE.
I’m seeing the screen below which wasn’t there before and feels like a tiny bug.
