Hello I wanted to know if I buy the perpetual license for an android player and it breaks, can I change the license to another player?
Yes you certainly can do.
You can delete the old device record in Customer Portal, and then license the new device. You’ll need to ensure you install the correct version of the Player for the license you hold.
